Instead of providing overlays as external files, you may alternatively leverage Juju’s support for multi-document YAML files and provide both the base overlay and any required overlays as a single file.
To do so, the contents of each overlay can be appended after the base bundle contents using the special YAML document separator token ---
as the delimiter. For example:
applications:
mysql:
charm: "cs:mysql-57"
num_units: 1
to: ["lxd:wordpress/0"]
--- # This is part of overlay 1
applications:
mysql:
num_units: 1
--- # This is part of overlay 2
applications:
mysql:
trust: true
When processing multi-document bundles, Juju will treat the first document as the base bundle and any subsequent document as an overlay.
