See also: Model (
ops.model.Model
In order to make use of file
resources in a charm, the Charmed Operator Framework provides a helper method to fetch the path of a file resource. Consider this simple resource definition:
resources:
my-resource:
type: file
filename: somefile.txt
description: test resource
In the charm code, we can now use Model.resources.fetch(<resource_name>)
to get the path to the resource, then manipulate it as we need:
import logging
from ops.model import ModelError, BlockedStatus, ErrorStatus
logger = logging.getLogger(__name__)
def _on_config_changed(self, event):
# Get the path to the file resource named 'my-resource'
try:
resource_path = self.model.resources.fetch("my-resource")
except ModelError as e:
self.unit.status = BlockedStatus(
"Something went wrong when claiming resource 'my-resource; "
"run `juju debug-log` for more info'"
# might actually be worth it to just reraise this exception and let the charm error out;
# depends on whether we can recover from this.
logger.error(e)
return
except NameError as e:
"Resource 'my-resource' not found; "
"did you forget to declare it in metadata.yaml?"
logger.error(e)
return
# Open the file and read it
with open(resource_path, "r") as f:
content = f.read()
# do something
The fetch()
method will raise a ModelError
if the resource does not exist, and returns a Python Path
object to the resource if it does.
Note: During development, it may be useful to specify the resource at deploy time to facilitate faster testing without the need to publish a new charm/resource in between minor fixes. In the below snippet, we create a simple file with some text content, and pass it to the Juju controller to use in place of any published my-resource
resource:
echo "TEST" > /tmp/somefile.txt
charmcraft pack
juju deploy ./my-charm.charm --resource my-resource=/tmp/somefile.txt
