See first: Juju | Application configuration, Juju | How to configure an application
Contents:
- Define a configuration option
- Observe the
config-changed
event and define the event handler - (If applicable) Update and restart the Pebble layer
- Verify the configuration option
In the charmcraft.yaml
file of the charm, under config.options
, add a configuration definition, including a name, a description, the type, and the default value. The example below shows how to define two configuration options, one called name
of type string
and default value Wiki
, and one called skin
with type string
and default value vector
config:
options:
name:
default: Wiki
description: The name, or Title of the Wiki
type: string
skin:
default: vector
description: skin for the Wiki
type: string
See more: File
charmcraft.yaml
>config
Observe the config-changed
In the src/charm.py
file of the charm project, in the __init__
function of the charm, set up an observer for the config changed event and pair that with an event handler:
self.framework.observe(self.on.config_changed, self._on_config_changed)
See more: Event
config-changed
Then, in the body of the charm definition, define the event handler. Here you may want to read the current configuration value, validate it (Juju only checks that the type is valid), and log it, among other things. Sample code for an option called server-port
, with type integer
, and default value 8000
def _on_config_changed(self, event):
port = self.config["server-port"]
if int(port) == 22:
self.unit.status = ops.BlockedStatus("invalid port number, 22 is reserved for SSH")
return
logger.debug("New application port is requested: %s", port)
self._update_layer_and_restart(None)
See more:
ops.CharmBase.config
- Multiple configuration values can be changed at one time through Juju, resulting in only one
config_changed
event. Thus, your charm code must be able to process more than one config value changing at a time. - If
juju config
is run with values the same as the current configuration, theconfig_changed
event will not run. Therefore, if you have a single config value, there is no point in tracking its previous value – the event will only be triggered if the value changes. - Configuration cannot be changed from within the charm code. Charms, by design, aren’t able to mutate their own configuration by themselves (e.g., in order to ignore an admin-provided configuration), or to configure other applications. In Ops, one typically interacts with config via a read-only facade.
If your charm is a Kubernetes charm and the config affects the workload: Update the Pebble layer to fetch the current configuration value and then restart the Pebble layer.
Note that, at the time you’re handling a config-changed
event, the workload might not be ready yet; so make sure to check that the container can connect (by calling container.can_connect()
To verify that the configuration option works as intended, pack your charm, update it in the Juju model, and run juju config
followed by the name of the application deployed by your charm and then your newly defined configuration option key set to some value. For example, given the server-port
key defined above, you could try:
juju config <name of application deployed by your charm> server-port=4000
See more: Juju | How to manage applications > Configure an application
