Getting started with Juju on Kubernetes
Juju is the simplest way to deploy and manage applications deployed to Kubernetes. It takes the pain away from managing YAML files.
In this guide, you’ll be deploying a simple web application to a Kubernetes cluster deployed to your local machine.
Setting up
Instructions for readers on MS Windows and macOS
Install Multipass
If you’re not running Ubuntu, visit multipass.run. Multipass is a tool for quickly running virtual machines from any host operating system. This will allow you to create a fully-isolated test environment that won’t impact your host system.
Multipass provides a command line interface to launch, manage and generally fiddle about with instances of Linux. The downloading of a minty-fresh image takes a matter of seconds, and within minutes a VM can be up and running.
The Register
Create virtual machine
We want to be able to experiment with Juju and evaluate it without the testing impacting on the rest of our system. To enter a shell within a virtual machine microcloud that has 8 GB RAM allocated to it, execute this command:
$ multipass launch -n microcloud -m 8g -c 2 -d 20G
Launched: microcloud
Once multipass has downloaded the latest Long Term Support version of the Ubuntu operating system, you will be able to enter a command-line shell:
$ multipass shell microcloud
multipass@microcloud:~$
Install microk8s
microk8s is “single node Kubernetes done right”. From the website:
The smallest, fastest, fully-conformant Kubernetes that tracks upstream releases and makes clustering trivial. MicroK8s is great for offline development, prototyping, and testing. Use it on a VM as a small, cheap, reliable k8s for CI/CD.
snap install microk8s
Need to install snap?
Visit the snapcraft homepage for installation instructions. Snap makes software installation trivial and secure.
