Kubernetes – also known as K8s – provides a flexible architecture for Cloud Native applications at scale. The Juju Charmed OLM manages multi-container workloads on K8s. This guide takes you through the registration steps necessary to connect the two systems.
You don’t need to have previous knowledge of Juju or Charmed Operators to follow this guide.
Contents:
Install the Juju client
Juju is a single binary executable that is published and supported on multiple operating systems and CPU architectures.
OS | Method |
Linux | snap install --classic juju |
macOS | brew install juju |
Windows | Download the signed Juju installer, md5, signature |
Alternative installations: You can find instructions on installing development releases or building from the source in the Juju installation page.
Installing Kubectl
Kubectl is a command-line tool that allows you to run commands against Kubernetes clusters. If you have access to a cluster, you might already have it installed. If not, you can follow these instructions to download and install the binary.
Gaining access to a Kubernetes cluster
Juju supports a variety of Kubernetes distributions running on your laptop, private infrastructure, or public cloud. You can connect Juju to your existing K8s cluster or get one based on the recommendations below. If you are new to Kubernetes, we recommend following this guide with MicroK8s.
Use Case | Recommended Action |
Local development, testing and experimentation | Install MicroK8s |
Multi-node testing/production on a private cloud | Install Charmed Kubernetes |
Multi-node testing/production on the public cloud | Install Charmed Kubernetes with the relevant integrator charm |
Use a hosted Kubernetes distribution | Enable the service via the provider |
We also have guides for creating clusters on the following Kubernetes distributions:
If your distribution is not listed above, you are still able to use Juju on any cluster to which you have sufficient access privileges, recorded in a kubeconfig entry.
Connecting Juju to your Kubernetes cluster
Register the cluster with Juju
Juju will look for the kube configuration files to find the cloud definition.
You can see what clouds Juju has found by running: juju clouds
If for any reason that can’t be done automatically, you can manually point Juju to the cluster’s configuration file.
Manually exposing the cluster's configuration file
Copy the cluster’s configuration file from the master node to your local machine and save it as $HOME/.kube/config
, then run
juju add-k8s <k8s-name>
If Juju can see your cluster (juju clouds
), move on to Create a Juju controller.
Some clouds will require extra steps configure the cluster to work with Juju:
a. When running MicroK8s
The cluster is registered with Juju automatically, but we have to enable the storage
and dns
addons.
microk8s enable storage dns
Then move on to Create a Juju controller.
b. When you’re already able to interact with your cluster via kubectl
Juju will automatically look in the standard kube configuration file.
c. When you have used Juju to deploy Charmed Kubernetes
mkdir ~/.kube
juju scp kubernetes-master/0:/home/ubuntu/config ~/.kube/config
The Juju controller is a central software agent that oversees applications managed with Juju. It is created via the juju bootstrap
command.
juju bootstrap <cloud-name> <controller-name>
Cloud name is microk8s
or <cloud-name>
specified previously.
Config file:
The command above assumes that the config file is located at $HOME/.kube/config
(or it has been loaded manually) and you can communicate to your cluster via kubectl.
To check that you have configured kubectl correctly, execute the command:
kubectl get nodes
Then move on to Add a model.
Deploy workloads
Add a model
Before deploying applications with charmed operators, Juju users create a “model”. In the Kubernetes context, models are namespaces.
A model is a canvas on a particular cloud/k8s-cluster. The model is used to group applications that are being operated together for a common purpose on a common substrate. The model will capture the applications, their integration, configuration, and resource allocation.
Since each model is on a single substrate, and the service as a whole may span multiple clouds/k8s-clusters, it may require several models to provide the canvases for all the different applications in the service.
The model is a workspace for inter-related applications. It is an abstraction over applications, machines hosting them and other components such as persistent storage.
To add a model, use the juju add-model
command:
juju add-model <model-name>
Inside the cluster, adding a Juju model creates a Kubernetes namespace with the same name. The namespace hosts all of the pods and other resources, except global resources.
Deploy workloads
The fundamental purpose of Juju is to deploy and manage software applications in a way that is easy and repeatable. All this is done with the help of charmed operators , which are bits of code that contain all the necessary intelligence to do these things. Charmed operators can exist online (in the Charm Store) or on your local filesystem (previously downloaded from the store or written locally).
As an example, we will deploy Mattermost, an open-source, self-hostable online chat service using PostgreSQL as its database.
Typically, applications are deployed using the online charmed operators. This ensures that you get the latest version of the charm. Deploying in this way is straightforward:
Deploy Mattermost:
juju deploy mattermost-k8s
When deployed, this outputs:
Located charm "mattermost-k8s" in charm-store, revision 20
Deploying "mattermost-k8s" from charm-store charm "mattermost-k8s", revision 20 in channel stable
You can observe the deployment status with the following command:
watch -c juju status --format short --color
Then deploy the PostgreSQL Charm:
juju deploy postgresql-k8s
Located charm "postgresql-k8s" in charm-store, revision 9
Deploying "postgresql" from charm-store charm "postgresql-k8s", revision 9 in channel stable
At this point, both applications are deployed in the model located in the Kubernetes cluster, but they don’t know about each other. Next we will relate apps.
Relate Applications
Relations
Most applications rely on other applications to function correctly. For example, typically web apps require a database to connect to. Relations avoid the need for manual intervention when the charm’s environment changes. The charm will be notified of new changes, re-configure and restart the application automatically.
Relations are a Juju abstraction that enables applications to inter-operate. They are a communication channel between charmed operators.
A certain charm knows that it requires, say, a database and, correspondingly, a database charm knows that it is capable of satisfying another charm’s requirements. The act of joining such mutually-dependent charmed operators causes code (hooks) to run in each charm in such a way that both charmed operators can effectively talk to one another. When charmed operators have joined logically in this manner they are said to have formed a relation.
Create a relation
Creating a relation is straightforward. The add-relation command is used to set up a relation between two applications:
juju relate mattermost-k8s postgresql-k8s:db
This will satisfy Mattermost’s database requirement where PostgreSQL provides the appropriate structures (e.g. tables) needed for Mattermost to run properly.
Ambiguous relations If the charmed operators in question are versatile enough, Juju may need to be supplied with more information as to how the charmed operators should be joined. In this example, we had to specify to which postresql endpoint we wanted to connect: postgresql:db That’s because postgresql has multiple endpoints for syslog, db and db_admin.
Again, watch the deployment status with the following command until both charmed operators’ status is active
Which will return the following when the applications are related:
- mattermost/0: (agent:idle, workload:active) 8065/TCP
- postgresql/0: (agent:idle, workload:active) 5432/TCP
Your deployment is dynamic: If you need to scale, deploy other applications or move it around, Juju will adapt and maintain the relations active without the need of special configurations.
Access the application
To access the application locally, get the Pod name:
export APP_NAME=$(kubectl get pod -l app.kubernetes.io/name=mattermost -n <model-name> -o name)
And create a port-forward:
kubectl port-forward -n my-model $APP_NAME 8065
Open your browser and access the page http://localhost:8065. You should see the Mattermost home page.
Congratulations, you just deployed and integrated cloud-native applications in a Kubernetes cluster!
Next steps
This guide presents the core of Juju’s functionality - most applications will follow a similar workflow: bootstrap the controller in your cluster, add a model, deploy and relate applications. If you would like to see some examples of what you can do with Juju, our tutorials page has application specific guide. You can also try Juju on your own cloud or localhost
