Hi, I’m trying to setup a manual cloud but i got:
22:14:26 ERROR juju.cmd.juju.commands bootstrap.go:832 failed to bootstrap model: machine is already provisioned.
how I can solve this issue?
There was a prior strategy of uninstalling all Juju concerns when a manual machine agent was deemed to be shutting down permanently.
This however was fraught with danger as an incorrect determination of that condition made it possible to irrevocably lose a machine from the model - particularly catastrophic should it happen to a controller.
We no longer employ this strategy. Instead if you want to remove traces of Juju from a machine, just run the script that we deploy for this purpose.
It is located at /usr/sbin/remove-juju-services.
Thanks @manadart, this happened because i’m trying to setup manual cloud with this parameters
juju add-cloud --local
Cloud Types
lxd
maas
manual
openstack
vsphere
Select cloud type: manual
Enter a name for your manual cloud: idtolu-cloud
Enter the ssh connection string for controller, username@<hostname or IP> or <hostname or IP>: jotero@10.0.100.101
then failed with:
12:14:40 ERROR juju.cmd.juju.commands bootstrap.go:832 unable to contact api server after 1 attempts: unable to connect to API: x509: certificate signed by unknown authority (possibly because of "crypto/rsa: verification error" while trying to verify candidate authority certificate "juju-ca")
