Just trying to run the getting started tutorial on https://juju.is/docs/getting-started-with-juju
To replicate: you will need vagrant and virtualbox:
Here is my vagrantfile:
Vagrant.configure("2") do |config|
config.vm.box = "ubuntu/xenial64"
config.vm.network "private_network", ip: "172.16.1.20"
config.vm.hostname = "c1-master1"
config.vm.provider "virtualbox" do |vb|
vb.memory = 2096
vb.cpus = 2
end
config.ssh.insert_key = false
config.ssh.private_key_path = ['~/.vagrant.d/insecure_private_key', '~/.ssh/id_rsa']
config.vm.provision "file", source: "~/.ssh/id_rsa.pub", destination: "~/.ssh/authorized_keys"
end
Here is the commands I run after I ssh to the VM:
1 sudo snap install maas --channel=2.7
2 sudo maas init
3 sudo snap install juju --classic
4 sudo snap install lxd
5 lxd init --auto
6 sudo lxd init --auto
7 sudo juju bootstrap localhost overlord
I just get a nondescript error saying: ERROR no addresses match
