Charms in detail
Table of contents
Best practices
Repository Naming
Naming follows the convention of charm-<charm_name> for example charm-percona-cluster
The rationale behind this is quick and easy searching of the 1000s of github projects along with other reasons.
New to charms?
This covers aspects of charming which will be useful when creating them
Why charms?
The objective of charms is the following: take the complication of managing 100s potentially 1000s of configuration files and abstract them as python modules. Thus by abstraction creating a true insfrastructure as code.
One of the ways that charms achieves this goal is through what are called relations, you can think about this much like the Database relation charts you might have seen in previous roles, or at university, the concept is much the same.
Here’s an example from the Juju GUI:
What you are looking at here is a Kubernetes, rendered, using Juju and charms. Each of the circles represents an application, each of the lines represents what we call a relation.
More info and history on charms can be found here.
Charm writing
The operator framework has a tool which you can use to create a charm for you, to install the charm tools firstly install the snap:
sudo snap install charm
You can now create the charm:
charm create -t operator-python mynewcharm
Before we get start lets go over some of the concepts of charming.
How do relations work?
Relations between charms at a high level work through what are called interfaces, interfaces are the glue that sticks two or more charms together and allows them to communicate.
Some history
In the old framework (reactive) charms were found on github, and used the naming convention of interface-<interface-name>
. This stays with the new framework.
The major change is the removal of requires.py
and provides.py
these are now replaced by a simplied interface_<interface_name>.py
Here’s the picture you might have in when you think of charm relations:
The problem with this conception is what if want to create a new charm to use somecharm:relation, well then not only do I have to create a new charm, and program the relation into it, I also have to adapt my original charm to work for my new charm. The two components are too closely coupled.
So the charm framework deals with this by decoupling the relations, this is where we move onto the next section.
Charm writing
TODO: Change this for the new charm generation tools
To start writing charms you will need to setup a development environment with git and a skeleton charm.
mkdir mynewcharm
cd $_
Included in the docs directory of this repository is a set of tools, we’re going to use the letscharm script to initialise a set of charms for our use.
./tools/letscharm.py
This tool will ask you whether you are creating a K8S charm or a IAAS charm. Pick the correct one as appropriate.
Add the operator framework
To begin a new charm, you will need to import the operator framework. The charm operator framework is imported by adding the framework in the ‘lib’ diretory and as a submodule:
git submodule add https://github.com/canonical/operator mod/operator
ln -s ../mod/operator/ops lib/ops
Add interface dependences
To begin a new charm we should take a note of any interfaces that might be needed, the operator framework uses interfaces as dependencies.
These dependencies are pulled in as git submodules, and should be added to the .gitmodules
file, an example file looks like this:
[submodule "mod/operator"]
path = mod/operator
url = https://github.com/canonical/operator
[submodule "mod/interface-mysql"]
path = mod/interface-mysql
url = git@github.com:johnsca/interface-mysql.git
[submodule "mod/interface-http"]
path = mod/interface-http
url = git@github.com:johnsca/interface-http.git
[submodule "mod/resource-oci-image"]
path = mod/resource-oci-image
url = git@github.com:johnsca/resource-oci-image.git
You can then pull in those dependencies with the following commands:
git submodule init
git submodule update
These commands will pull in the dependencies to mod, although we will be referencing from the lib
directory. To fix this you will need to create symbolic references.
ln -s ./mod/interface-mysql/interface_mysql.py ./lib/interface_mysql.py
This is requied for all of the required submodules.
You can learn more about writing Interfaces here
Imports
The operator charms are invoked as scripts on the running machine. As such you will be required to add a shbang at the top of the python file:
#!/usr/bin/env python3
After this, you will then need to adapt the system path to import the framework:
import sys
sys.path.append('lib')
Once this is done, you can then move on to import the Framework classes
from ops.charm import CharmBase
from ops.main import main
from ops.framework import StoredState
from oci_image import OCIImageResource
Followed by any other imports, for example, interfaces:
from interface_mysql import MySQLClient
Creating the charm class
All Operator Framework charms should inherit from the CharmBase
class. This gives them access to the internals
For example:
class MyCharm(CharmBase):
The charm __init__
method
The charm init method has the following signature:
def __init__(self, framework, key)
1. Reference to the class instance
2. A reference to the framework
3. key (described below)
Number 3. Is yet unused in the framework.
Once you have the above __init__
signature. You will need to call super:
def __init__(self, framework, key):
super.__init__(framework, key)
You can then follow up the rest of the method with calls to set our state and our required interfaces for example:
self.state.set_defaults(is_started=False)
self.mysql = MySQLClient(self, 'mysql')
The charm model
This is the central place to get all relevant charm information so that you can configure your charm.
The charm model has the following properties:
- unit
- app
- relations - A relation mapping
- config - The charm configuration
- resources
- pod - the Kubernetes pod
- storages - The charm storage - (TODO)
Charm metadata is retrieved from the meta framework attribute:
meta = self.framework.meta
The same can be done for the charm configuration data too:
config = self.framework.config
Hooking into events
In the __init__
call you can setup events to be called, for example when the database is available:
self.framework.observe(
self.mysql.on.database_available,
self.configure_pod
A popular event to track in the framework is the config_changed
event:
self.framework.observe(self.on.config_changed, self.configure_pod)
To get a list of events for an interface you will need to check the docs of that interface. For framework events see here
Your event listener methods should accept the event as an arguement. The required signature is below:
def my_event_listener(self, event):
pass
You are able to add additional params if you so wish but they must be optional, otherwise a TypeError
will be thrown.
Deferring events
In the new framework events can now be deferred. When an event is deferred:
- Parameters will be saved when events are deferred;
- Parameters will be restored when events are reemitted;
To defer an event, all you need to is called defer()
. An example of this can be found below:
def on_db_peer_relation_changed(self, event):
if not self.state.ready:
event.defer()
return
NOTE: ActionEvents cannot be deferred. Doing so will trigger a
RuntimeError
Subordinate Charms
Charm Actions
TODO
Migrating from the old (reactive) framework
For the most part and charm code you write in the old framework may more or less be portable to the new Framework.
Testing
Please find the testing guide here
Useful links
Juju
