Below is the roadmap for the Discourse K8s Operator.
October 2022 to April 2023
- Transition to sidecar. The charm as currently published in the “stable” channel is using the older “pod-spec” approach to k8s charming. We plan to complete the conversion to the sidecar approach, adding liveness/readiness checks as appropriate.
- Update CI/CD. The IS DevOps team has some common workflows and we’ll integrate with these to add linting, unit tests, static code analysis, integration tests and inclusive naming checks.
- Integration with COS.
- Documentation improvements - updating the home page, integrating the Diataxis documentation framework and including project governance information.
- SAML integration test.
