Container configuration
This charm exposes several configurations to tweak the behaviour of discourse. These can by changes by running juju config [charm_name] [configuration]=[value]
. Below you can find some of the options that will allow you to modify the charm’s behaviour:
- CORS policies can be modified with the settings cors_origin and enable_cors
- The developer mails can be set through developer_emails
- Throttle level protections provided by discourse can be changed via throttle_level
For a comprehensive list of configuration options check the configuration reference.
