Added a note to clarify (a) (local charm). Will look into (b) (how to provide credentials for pulling a container image from a private registry).
Asked around. Long story short: From our point of view, it doesnāt make sense to add information about that in the tutorial. The idea is that a charm is made to be published, and then everything about it goes public. For development you can however use a local image, if you wish.
In other words, Juju Charms are not for application development (i.e. deploying application that are developed in-house), is that what youāre saying?
The Kubernetes Charms tutorial show-cases a containerized fastapi Python application (it could as well be Django, Flask, RoR or anything else someone would develop a Web application in). How such a charm is deployed is explained in Juju | Create a minimal Kubernetes charm, Validate your Charm. Itās neither obvious nor explained, though, what happens with the image that is passed along to the juju deploy
command with the --resource
option.
IIUC, the image is uploaded to the Juju controller, which manages a local copy of it. In other words, that explains why you wouldnāt use a private container registry for your images, because you upload them directly to your cluster (i.e. the Juju controller).
In my opinion, it would indeed make sense to explain these inner workings in the documentation.
Based on my investigation: No, there is currently not.
The --resource
flag accepts 3 types of arguments:
- a charm revision number (if the charm is on Charmhub)
- a path to a local file
- a link to a public OCI image
I will update the docs to make this clearer ā and thanks for bringing it up.
Just a friendly reminder on adding a few words of clarification about what happens to the local charm when itās being deployed (I suppose uploaded and managed by the Juju controller without any reference to an external image registry).
Providing authentication credentials for private OCI registries
As a side note, it should be possible to provide a JSON or YAML file with an image reference and optionally username and password (i.e. an OCI image resource) to allow the Juju controller to pull an image from a private registry.
"ImageName": "my.private.repo.com/a/b:latest",
"username": "harry",
"password": "supersecretpassword"
or
registrypath: my.private.repo.com/a/b:latest
username: harry
password: supersecretpassword
Thanks @hpidcock for pointing this out on the Charmhub chat!
Hi @bittner, thanks for your input!
I think a note on alternative ways to specify the resource goes beyond the scope of this tutorial (in a tutorial weāre allowed to be opinionated and we donāt have to cover all the options). However:
Iāve updated the resource command docs (they wonāt go live till 3.3, but that should be soon): https://github.com/juju/juju/pull/16058/files
We also have a set of how-to guides on how to manage charm resources: https://juju.is/docs/juju/manage-charm-resources
Iāve just used the examples in your comments to update the reference doc on charm resources: https://juju.is/docs/juju/charm-resource (you may have to refresh the page to get past cached content)
I just noticed that the examples donāt match: The JSON uses ImageName
for the container image reference, while the YAML uses registrypath
. Can you double-check with @hpidcock whether both are working examples, or which one is correct? ā I was unable to find matching content in the OCI specification docs.
I wondered about that too. @hpidcock, could you please clarify? Why does the JSON example use ImageName
and the YAML registrypath
? (Copying the examples below for convenience.)
JSON:
YAML:
username: harry
Hi everyone, I noticed that the article frequently mentions āJuju OLMā. Iāve started reading up on Juju recently and this is the first time I come across the term. Since juju.is/docs/olm now redirects to juju.is/docs/juju, is āJuju OLMā now simply referred to as āJujuā in the rest of the documentation?
I thought I had replace all instances of āJuju OLMā with just āJujuā. Iāll check again, thanks!
