Usage: juju update-credential [options] <cloud-name> <credential-name>
Summary:
Updates a controller credential for a cloud.
Options:
-c, --controller (= "")
Controller to operate in
--credential (= "")
Name of credential to update
Details:
Cloud credentials for controller are used for model operations and manipulations. Since it is common to have long-running models, it is also common to have these cloud credentials become invalid during models’ lifetime.
When this happens, a user must update the cloud credential that a model was created with to the new and valid details on controller.
This command allows to update an existing, already-stored, named, cloud-specific controller credential.
NOTE: This is the only command that will allow you to manipulate cloud credential for a controller. All other credential related commands, such as add-credential
, remove-credential
and credentials
deal with credentials stored locally on the client not on the controller.
Examples:
juju update-credential aws mysecrets
See also:
