Usage: juju sync-agent-binaries [options]
Summary:
Copy agent binaries from the official agent store into a local model.
Options:
--all (= false)
Copy all versions, not just the latest
--destination (= "")
Local destination directory
DEPRECATED: use --local-dir instead
--dev (= false)
Consider development versions as well as released ones
DEPRECATED: use --stream
instead
--dry-run (= false)
Don’t copy, just print what would be copied
--local-dir (= "")
-m, --model (= "")
Model to operate in. Accepts [<controller name>:]<model name>
--public (= false)
Tools are for a public cloud, so generate mirrors information
--source (= "")
Local source directory
--stream (= "")
Simplestreams stream for which to sync metadata
--version (= "")
Copy a specific major[.minor] version
Details:
This copies the Juju agent software from the official agent binaries store (located at https://streams.canonical.com/juju) into a model. It is generally done when the model is without Internet access.
Instead of the above site, a local directory can be specified as source. The online store will, of course, need to be contacted at some point to get the software.
Examples:
Download the software (version auto-selected) to the model:
juju sync-agent-binaries --debug
Download a specific version of the software locally:
juju sync-agent-binaries --debug --version 2.0 --local-dir=/home/ubuntu/sync-agent-binaries
Get locally available software to the model:
juju sync-agent-binaries --debug --source=/home/ubuntu/sync-agent-binaries
See also:
Aliases:
sync-tools
