Command subnets
Usage: juju subnets [options] [--space <name>] [--zone <name>] [--format yaml|json] [--output <path>]
Summary:
List subnets known to Juju.
Options:
--format (= yaml)
Specify output format (json|yaml)
-m, --model (= "")
Model to operate in. Accepts [<controller name>:]<model name>
-o, --output (= "")
Specify an output file
--space (= "")
Filter results by space name
--zone (= "")
Filter results by zone name
Details:
Displays a list of all subnets known to Juju. Results can be filtered using the optional --space and/or --zone arguments to only display subnets associated with a given network space and/or availability zone. Like with other Juju commands, the output and its format can be changed using the --format and --output (or -o) optional arguments. Supported output formats include “yaml” (default) and “json”. To redirect the output to a file, use --output.
Aliases:
list-subnets
