Command status
The juju status command shows the current status of a deployment of any given model.
Deploying this example workload to a new model (replicate by executing the commands shown) results in the following output from juju status:
# Deploy example workload
juju deploy hello-juju
juju deploy ntp
juju relate hello-juju ntp
$ juju status
Model    Controller  Cloud/Region         Version  SLA          Timestamp
default  test        localhost/localhost  2.9.27   unsupported  10:03:25+13:00
App         Version  Status  Scale  Charm       Channel  Rev  Exposed  Message
hello-juju           active      1  hello-juju  stable     8  no
ntp         3.5      active      1  ntp         stable    47  no       chrony: Ready, time sync disabled in container
Unit           Workload  Agent  Machine  Public address  Ports    Message
hello-juju/0*  active    idle   0        10.133.79.245   80/tcp
  ntp/0*       active    idle            10.133.79.245   123/udp  chrony: Ready, time sync disabled in container
Machine  State    DNS            Inst id        Series  AZ  Message
0        started  10.133.79.245  juju-c4ebcb-0  focal       Running
Models
The first section reported relates to the overall model.
Model
The model’s name, as defined when performing juju bootstrap or the add-model command.
Controller
The controller’s name, as defined by the juju bootstrap command.
Cloud/Region
The cloud and region selected during juju bootstrap. Valid clouds are listed by the juju clouds command. Each cloud’s regions are listed by the juju regions command.
In this instance localhost refers to LXD.
Version
The version of Juju that is being run by the Juju agents within the model. Newer versions of the Juju client will always inter-operable with older versions of Juju.
Info: The Version relates to the deployed version of Juju on the controller and not the local version of Juju CLI. To obtain the local version of Juju, using juju version should suffice.
SLA
The “Support Level Agreement” for this model.
Timestamp
The time when the controller gathered the information for the report.
Info: The Timestamp is of the Model time, not the local time.
Remote Applications (optional)
The remote applications section is not shown by default. Only when a remote-application (SAAS) is consumed, will it appear in the juju status output.
SAAS   Status  Store    URL
mysql  active  unknown  admin/cmr-model.mysql
Deploying a remote application will include the additional information.
SAAS / Remote Application
The name of the remote application.
Status
Indicates the status of the remote application from the perspective of the consumer side.
Store
Describes the source of the application. Will report “unknown” when Juju is unable to determine its source.
URL
The “offer URL” that describes how the Juju controller can connect with remote applications.
Applications
The application section aggregates information that applicable to all units of each application. This include the details about the charm(s) that are deployed and an overall status code.
App
The application name, as provided during juju deploy. The application name can differ from the charm’s default name to enable multiple logical services running the same underlying application.
Version
The version number of the application itself, not the charm.
Status
May be “active”, “blocked”, “error”, “maintenance”, “waiting”. The “blocked” state implies that manual intervention is required. Normally, “blocked” can resolved be adding a relation or setting configuration values. “error” indicates that the charm’s code itself has encountered an error. To resolve this, contact the charm’s author.
Scale
Number of units of this application. Indicates a difference between the desired units and the actual count with a fraction.
Charm
The original charm’s name, which can differ from the App name.
Channel
The channel this application was deployed from.
Rev
The charm’s revision number.
Exposed
Whether this application has been exposed with juju expose or not (“yes” or “no”).
Message
Any messages that are applicable to all units within the application that provide key stages or snapshots of a charm from the author of the charm to the operator.
Units
The units section provides individual information about every unit for a given model. A unit comprises of a singular application unit and can be identified with the application name, followed by the unit number.
Subordinate application units are list underneath the principal units in hierarchical form, once the applications have been related.
Unit
The unit name defined from the application name and a unit number for a given application. Each unit number is uniquely incremented to that application, for example hello-juju/0, hello-juju/1 and ntp/0, ntp/1.
Workload
The workload status of a given unit.
Agent
The Juju agent status of a given unit.
Machine
The corresponding machine ID of a unit.
Info: Subordinates have no corresponding machine ID, instead they run on the same machine as their principal unit.
Public address
The public address of a given unit.
Ports
A list of ports and associated protocols that are available for the unit.
Message
Any messages that are applicable to the unit that provide key stages or snapshots of a charm from the author of the charm to the operator.
Machine
Machine represents the physical/virtual infrastructure for running the units and therefore applications upon.
Machine
The machine unique identifier.
State
The state of the machine.
DNS
The DNS of the application.
Inst id
The instance identifier that can be used to locate the machine within the physical/virtual infrastructure.
In the example the instance id refers to LXD and can be located using lxc list:
|     NAME      |  STATE  |         IPV4         | IPV6 |   TYPE    | SNAPSHOTS |
| juju-c4ebcb-0 | RUNNING | 10.133.79.245 (eth0) |      | CONTAINER | 0         |
| juju-d8dbef-0 | RUNNING | 10.133.79.210 (eth0) |      | CONTAINER | 0         |
Series
The underlying base of the machine. focal refers to the Ubuntu 20.04 release.
AZ
The availability zone the machine is currently occupying. This is not present on some clouds (for example, LXD).
Message
Any notes, messages or actions to be highlights about a given machine.
