Usage: juju spaces [options] [--short] [--format yaml|json] [--output <path>]
Summary:
List known spaces, including associated subnets.
Options:
--format (= tabular)
Specify output format (json|tabular|yaml
-m, --model (= "")
Model to operate in. Accepts [<controller name>:]<model name>
-o, --output (= "")
Specify an output file
--short (= false)
only display spaces.
Details:
Displays all defined spaces. If --short
is not given both spaces and their subnets are displayed, otherwise just a list of spaces. The --format
argument has the same semantics as in other CLI commands - “yaml” is the default. The --output
argument allows the command output to be redirected to a file.
Aliases:
list-spaces
