Command 'show-operation'
See also: run, operations, show-task
Show results of an operation.
Usage
juju show-operation [options] <operation-id>
Options
Flag Default Usage
--B, --no-browser-login false Do not use web browser for authentication
--format yaml Specify output format (json|yaml)
--m, --model Model to operate in. Accepts [<controller name>:]<model name>|<model UUID>
--o, --output Specify an output file
--utc false Show times in UTC
--wait -1s Wait for results
--watch false Wait indefinitely for results
Examples
juju show-operation 1
juju show-operation 1 --wait=2m
juju show-operation 1 --watch
Details
Show the results returned by an operation with the given ID.
To block until the result is known completed or failed, use the --wait option with a duration, as in --wait 5s or --wait 1h. Use --watch to wait indefinitely.
The default behavior without --wait or --watch is to immediately check and return; if the results are “pending” then only the available information will be displayed. This is also the behavior when any negative time is given.
