Usage: juju set-constraints [options] <application> <constraint>=<value> ...
Summary:
Sets machine constraints for an application.
Options:
-m, --model (= "")
Model to operate in. Accepts [<controller name>:]<model name>
Details:
Sets constraints for an application, which are used for all new machines provisioned for that application. They can be viewed with juju get- constraints
By default, the model is the current model.
Application constraints are combined with model constraints, set with juju set-model-constraints
, for commands (such as juju deploy
) that provision machines for applications. Where model and application constraints overlap, the application constraints take precedence.
Constraints for a specific model can be viewed with juju get-model- constraints
This command requires that the application to have at least one unit. To apply constraints to the first unit set them at the model level or pass them as an argument when deploying.
Examples:
juju set-constraints mysql mem=8G cores=4
juju set-constraints -m mymodel apache2 mem=8G arch=amd64
See also:
get-constraints, get-model-constraints, set-model-constraints
