Removes storage from the model.
Usage
juju remove-storage [options] <storage> [<storage> ...]
Options
Flag | Default | Usage |
--B , --no-browser-login
--force |
false | Remove storage even if it is currently attached |
--m , --model
--no-destroy |
false | Remove the storage without destroying it |
Examples
Remove the detached storage pgdata/0:
juju remove-storage pgdata/0
Remove the possibly attached storage pgdata/0:
juju remove-storage --force pgdata/0
Remove the storage pgdata/0, without destroying the corresponding cloud storage:
juju remove-storage --no-destroy pgdata/0
Details
Removes storage from the model. Specify one or more storage IDs, as output by “juju storage”.
By default, remove-storage will fail if the storage is attached to any units. To override this behaviour, you can use “juju remove-storage --force”. Note: forced detach is not available on container models.
