Usage: juju logout [options]
Summary:
Logs a Juju user out of a controller.
Options:
-c, --controller (= "")
Controller to operate in
--force (= false)
Force logout when a locally recorded password is detected
Details:
If another client has logged in as the same user, they will remain logged in. This command only affects the local client.
The command will fail if the user has not yet set a password (juju change-user-password
). This scenario is only possible after juju bootstrap
since juju register
sets a password. The failing behaviour can be overridden with the --force
option.
If the same user is logged in with another client system, that user session will not be affected by this command; it only affects the local client. By default, the controller is the current controller.
Examples:
juju logout
See also:
