Command 'juju update-secret-backend'
See also: How to manage secret backends
Usage:
juju update-secret-backend [options] <backend-name>
Summary:
Update an existing secret backend on the controller.
Global Options:
--debug  (= false)
Equivalent to --show-log --logging-config=<root>=DEBUG
-h, --help  (= false)
--logging-config (= "")
--quiet  (= false)
Show no informational output
--show-log  (= false)
--verbose  (= false)
Show more verbose output
Command Options:
-c, --controller (= "")
Controller to operate in
--config  (= )
Path to yaml-formatted configuration file
--force  (= false)
Force update even if the backend is unreachable
--reset  (= )
Reset the provided comma delimited config keys
Details:
Updates a new secret backend for storing secret content.
You must specify a name for the backend to update, followed by any necessary backend specific config values. Config may be specified as key values ot read from a file. Any key values override file content if both are specified.
Config attributes may be reset back to the default value using --reset.
To rotate the backend access credential/token (if specified), use the “token-rotate” config and supply a duration. To reset any existing token rotation period, supply a value of 0.
Examples:
juju update-secret-backend myvault --config /path/to/cfg.yaml
juju update-secret-backend myvault name=myvault2
juju update-secret-backend myvault token-rotate=10m --config /path/to/cfg.yaml
juju update-secret-backend myvault endpoint=https://vault.io:8200 token=s.1wshwhw
juju update-secret-backend myvault token-rotate=0
juju update-secret-backend myvault --reset namespace,ca-cert
See also:
add-secret-backends
list-secret-backends
remove-secret-backend
show-secret-backend
