See also: How to manage applications
Usage:
juju trust [options] <application name>
Summary:
Sets the trust status of a deployed application to true.
Global Options:
--debug (= false)
-h, --help (= false)
--logging-config (= "")
--quiet (= false)
Show no informational output
--show-log (= false)
--verbose (= false)
Show more verbose output
Command Options:
-m, --model (= "")
Model to operate in. Accepts [<controller name>:]<model name>|<model UUID>
--remove (= false)
Remove trusted access from a trusted application
--scope (= "")
k8s models only - needs to be set to ‘cluster’
Details:
Sets the trust configuration value to true.
On k8s models, the trust operation currently grants the charm full access to the cluster. Until the permissions model is refined to grant more granular role based access, the use of ‘–scope=cluster’ is required to confirm this choice.
Examples:
juju trust media-wiki
juju trust metallb --scope=cluster
See also:
config
