Command 'juju switch'
See also: How to manage controllers, How to manage models
Usage:
juju switch [options] [<controller>|<model>|<controller>:|:<model>|<controller>:<model>]
Summary:
Selects or identifies the current controller and model.
Global Options:
--debug  (= false)
-h, --help  (= false)
--logging-config (= "")
--quiet  (= false)
Show no informational output
--show-log  (= false)
--verbose  (= false)
Show more verbose output
Command Options:
Details:
When used without an argument, the command shows the current controller and its active model.
When a single argument without a colon is provided juju first looks for a controller by that name and switches to it, and if it’s not found it tries to switch to a model within current controller. mycontroller: switches to default model in mycontroller, :mymodel switches to mymodel in current controller and mycontroller:mymodel switches to mymodel on mycontroller. The juju models command can be used to determine the active model (of any controller). An asterisk denotes it.
Examples:
juju switch
juju switch mymodel
juju switch mycontroller
juju switch mycontroller:mymodel
juju switch :mymodel
See also:
controllers
models
show-controller
I would like to propose a change in behavior of “juju switch”.
Since I often find myself altering between two models for test in one, and waiting for something to happen in the other model.
I would be more efficient if the behavior was to toggle back to the last used model, rather than showing the actual model active. I normally use “juju status” to see which model I’m attached to. So “juju switch” makes not so much sense to get this info.
This would also be efficient when moving between different cloud/controllers as this otherwise forces me to switch a few times before getting it right with names for all controllers, models etc.
