Command 'juju show-task'
Usage:
juju show-task [options] <task ID>
Summary:
Show results of a task by ID.
Global Options:
--debug  (= false)
-h, --help  (= false)
--logging-config (= "")
--quiet  (= false)
Show no informational output
--show-log  (= false)
--verbose  (= false)
Show more verbose output
Command Options:
--format  (= plain)
Specify output format (json|plain|yaml)
-m, --model (= "")
Model to operate in. Accepts [<controller name>:]<model name>|<model UUID>
-o, --output (= "")
Specify an output file
--utc  (= false)
Show times in UTC
--wait  (= -1s)
Maximum wait time for a task to complete
--watch  (= false)
Wait indefinitely for results
Details:
Show the results returned by a task with the given ID.
To block until the result is known completed or failed, use the --wait option with a duration, as in --wait 5s or --wait 1h. Use --watch to wait indefinitely.
The default behavior without --wait or --watch is to immediately check and return; if the results are “pending” then only the available information will be displayed. This is also the behavior when any negative time is given.
Note: if Juju has been upgraded from 2.6 and there are old action UUIDs still in use, and you want to specify just the UUID prefix to match on, you will need to include up to at least the first “-” to disambiguate from a newer numeric id.
Examples:
juju show-task 1
juju show-task 1 --wait=2m
juju show-task 1 --watch
See also:
run
operations
show-operation
