Command 'juju show-operation'
Usage:
juju show-operation [options] <operation-id>
Summary:
Show results of an operation.
Global Options:
--debug  (= false)
-h, --help  (= false)
--logging-config (= "")
--quiet  (= false)
Show no informational output
--show-log  (= false)
--verbose  (= false)
Show more verbose output
Command Options:
--format  (= yaml)
Specify output format (json|yaml)
-m, --model (= "")
Model to operate in. Accepts [<controller name>:]<model name>|<model UUID>
-o, --output (= "")
Specify an output file
--utc  (= false)
Show times in UTC
--wait  (= -1s)
Wait for results
--watch  (= false)
Wait indefinitely for results
Details:
Show the results returned by an operation with the given ID.
To block until the result is known completed or failed, use the --wait option with a duration, as in --wait 5s or --wait 1h. Use --watch to wait indefinitely.
The default behavior without --wait or --watch is to immediately check and return; if the results are “pending” then only the available information will be displayed. This is also the behavior when any negative time is given.
Examples:
juju show-operation 1
juju show-operation 1 --wait=2m
juju show-operation 1 --watch
See also:
run
operations
show-task
