Command 'juju set-application-base'
Usage:
juju set-application-base [options] <application> <base>
Summary:
Set an application’s base.
Global Options:
--debug  (= false)
Equivalent to --show-log --logging-config=<root>=DEBUG
-h, --help  (= false)
–logging-config (= “”)
--quiet  (= false)
Show no informational output
--show-log  (= false)
--verbose  (= false)
Show more verbose output
Command Options:
-m, --model (= "")
Model to operate in. Accepts [<controller name>:]<model name>|<model UUID>
Details:
The specified application’s base value will be set within juju. Any subordinates of the application will also have their base set to the provided value. A base can be specified using the OS name and the version of the OS, separated by @.
This will not change the base of any existing units, rather new units will use the new base when deployed.
It is recommended to only do this after upgrade-machine has been run for machine containing all existing units of the application.
To ensure correct binaries, run juju refresh before running juju add-unit.
