See also: How to manage secret backends
Usage:
juju remove-secret-backend [options] <backend-name>
Summary:
Removes a secret backend from the controller.
Global Options:
--debug (= false)
Equivalent to --show-log --logging-config=<root>=DEBUG
-h, --help (= false)
--logging-config (= "")
--quiet (= false)
Show no informational output
--show-log (= false)
--verbose (= false)
Show more verbose output
Command Options:
-c, --controller (= "")
Controller to operate in
--force (= false)
Force removal even if the backend stores in-use secrets
Details:
Removes a secret backend, used for storing secret content.
If the backend is being used to store secrets currently in use,
the --force
option can be supplied to force the removal, but be
warned, this will affect charms which use those secrets.
Examples:
juju remove-secret-backend myvault
juju remove-secret-backend myvault --force
See also:
add-secret-backend
list-secret-backends
show-secret-backend
update-secret-backend
