Command 'juju model-constraints'
See also: How to manage models
Usage:
juju model-constraints [options]
Summary:
Displays machine constraints for a model.
Global Options:
--debug  (= false)
-h, --help  (= false)
--logging-config (= "")
--quiet  (= false)
Show no informational output
--show-log  (= false)
--verbose  (= false)
Show more verbose output
Command Options:
--format  (= constraints)
Specify output format (constraints|json|yaml)
-m, --model (= "")
Model to operate in. Accepts [<controller name>:]<model name>|<model UUID>
-o, --output (= "")
Specify an output file
Details:
Shows constraints that have been set on the model with juju set-model-constraints. By default, the model is the current model. Model constraints are combined with constraints set on an application with juju set-constraints for commands (such as ‘deploy’) that provision machines/containers for applications. Where model and application constraints overlap, the application constraints take precedence. Constraints for a specific application can be viewed with juju constraints.
Examples:
juju model-constraints -m mymodel
See also:
models
constraints
set-constraints
