Command 'juju download'
Usage:
juju download [options] [options] <charm>
Summary:
Locates and then downloads a CharmHub charm.
Global Options:
--debug  (= false)
Equivalent to --show-log --logging-config=<root>=DEBUG
-h, --help  (= false)
--logging-config (= "")
--quiet  (= false)
Show no informational output
--show-log  (= false)
--verbose  (= false)
Show more verbose output
Command Options:
--arch (= "all")
Specify an arch <all|amd64|arm64|armhf|i386|ppc64el|riscv64|s390x>
--base (= "")
Specify a base
--channel (= "")
Specify a channel to use instead of the default release
--charmhub-url (= "https://api.charmhub.io")
Specify the Charmhub URL for querying the store
--filepath (= "")
Filepath location of the charm to download to
--no-progress  (= false)
Disable the progress bar
--series (= "all")
Specify a series. DEPRECATED use --base
Details:
Download a charm to the current directory from the CharmHub store by a specified name. Downloading for a specific base can be done via --base. --base can be specified using the OS name and the version of the OS, separated by @. For example, --base ubuntu@22.04.
Adding a hyphen as the second argument allows the download to be piped to stdout.
Examples:
juju download postgresql
juju download postgresql --no-progress - > postgresql.charm
See also:
info
find
