Command 'juju constraints'
Usage:
juju constraints [options] <application>
Summary:
Displays machine constraints for an application.
Global Options:
--debug  (= false)
-h, --help  (= false)
--logging-config (= "")
--quiet  (= false)
Show no informational output
--show-log  (= false)
--verbose  (= false)
Show more verbose output
Command Options:
--format  (= constraints)
Specify output format (constraints|json|yaml)
-m, --model (= "")
Model to operate in. Accepts [<controller name>:]<model name>|<model UUID>
-o, --output (= "")
Specify an output file
Details:
Shows machine constraints that have been set for an application with juju set-constraints. By default, the model is the current model. Application constraints are combined with model constraints, set with juju set-model-constraints, for commands (such as ‘deploy’) that provision machines for applications. Where model and application constraints overlap, the application constraints take precedence. Constraints for a specific model can be viewed with juju model-constraints.
Examples:
juju constraints mysql
juju constraints -m mymodel apache2
See also:
set-constraints
model-constraints
