Aliases: list-charm-resources
Usage:
juju charm-resources [options] <charm>
Summary:
Display the resources for a charm in a repository.
Global Options:
--debug (= false)
-h, --help (= false)
--logging-config (= "")
--quiet (= false)
Show no informational output
--show-log (= false)
--verbose (= false)
Show more verbose output
Command Options:
--channel (= "stable")
The channel of the charm
--format (= tabular)
Specify output format (json|tabular|yaml)
-m, --model (= "")
Model to operate in. Accepts [<controller name>:]<model name>|<model UUID>
-o, --output (= "")
Specify an output file
Details:
This command will report the resources and the current revision of each resource for a charm in a repository.
can be a charm URL, or an unambiguously condensed form of it, just like the deploy command.
Release is implied from the supplied. If not provided, the default series for the model is used.
Channel can be specified with --channel
. If not provided, stable is used.
Where a channel is not supplied, stable is used.
Examples:
# Display charm resources for the postgresql charm:
juju charm-resources postgresql
# Display charm resources for mycharm in the 2.0/edge channel:
juju charm-resources mycharm --channel 2.0/edge
