The information in this doc is based on Juju version 3.5.3, and may not accurately reflect other versions of Juju.
See also: deploy
Compare a bundle with a model and report any differences.
Usage
juju diff-bundle [options] <bundle file or name>
Options
Flag | Default | Usage |
-B , --no-browser-login |
--annotations |
false | Include differences in annotations |
--arch |
specify an arch <all|amd64|arm64|ppc64el|riscv64|s390x> | |
--base |
specify a base | |
--channel |
Channel to use when getting the bundle from Charmhub | |
-m , --model |
--map-machines |
Indicates how existing machines correspond to bundle machines | |
--overlay |
Bundles to overlay on the primary bundle, applied in order | |
--series |
specify a series. DEPRECATED: use --base |
Examples
juju diff-bundle localbundle.yaml
juju diff-bundle charmed-kubernetes
juju diff-bundle charmed-kubernetes --overlay local-config.yaml --overlay extra.yaml
juju diff-bundle charmed-kubernetes --base ubuntu@22.04
juju diff-bundle -m othermodel hadoop-spark
juju diff-bundle localbundle.yaml --map-machines 3=4
Details
Bundle can be a local bundle file or the name of a bundle in Charmhub. The bundle can also be combined with overlays (in the same way as the deploy command) before comparing with the model.
The map-machines option works similarly as for the deploy command, but existing is always assumed, so it doesn’t need to be specified.
Config values for comparison are always source from the “current” model generation.
Specifying a base will retrieve the bundle for the relevant store for the give base.
