Command debug-log
Usage: juju debug-log [options]
Summary:
Displays log messages for a model.
Options:
--color (= false)
Force use of ANSI color codes
--date (= false)
Show dates as well as times
--exclude-label (= )
Do not show log messages for these logging labels
--exclude-module (= )
Do not show log messages for these logging modules
-i, --include (= )
Only show log messages for these entities
--include-label (= )
Only show log messages for these logging labels
--include-module (= )
Only show log messages for these logging modules
-l, --level (= "")
Log level to show, one of [TRACE, DEBUG, INFO, WARNING, ERROR]
--limit (= 0)
Exit once this many of the most recent (possibly filtered) lines are shown
--location (= false)
Show filename and line numbers
-m, --model (= "")
Model to operate in. Accepts [<controller name>:]<model name>
--ms (= false)
Show times to millisecond precision
-n, --lines (= 10)
Show this many of the most recent (possibly filtered) lines, and continue to append
--no-tail (= false)
Stop after returning existing log messages
--replay (= false)
Show the entire (possibly filtered) log and continue to append
--tail (= false)
Wait for new logs
--utc (= false)
Show times in UTC
-x, --exclude (= )
Do not show log messages for these entities
Details:
This command provides access to all logged Juju activity on a per-model basis. By default, the logs for the currently select model are shown.
Each log line is emitted in this format:
   <entity> <timestamp> <log-level> <module>:<line-no> <message>
The “entity” is the source of the message: a machine or unit. The names for machines and units can be seen in the output of juju status.
The --include and --exclude options filter by entity. The entity can be a machine, unit, or application.
The --include-module and --exclude-module options filter by (dotted) logging module name. The module name can be truncated such that all loggers with the prefix will match.
The filtering options combine as follows:
All --include options are logically ORed together.
All --exclude options are logically ORed together.
All --include-label options are logically ORed together.
All --exclude-label options are logically ORed together.
All --include-module options are logically ORed together.
All --exclude-module options are logically ORed together.
The combined --include, --exclude, --include-label, --exclude-label, --include-module and --exclude-module selections are logically ANDed to form the complete filter.
Examples:
Exclude all machine 0 messages; show a maximum of 100 lines; and continue to append filtered messages:
juju debug-log --exclude machine-0 --lines 100
Include only unit mysql/0 messages; show a maximum of 50 lines; and then exit:
juju debug-log -T --include unit-mysql-0 --lines 50
Show all messages from unit apache2/3 or machine 1 and then exit:
juju debug-log -T --replay --include unit-apache2-3 --include machine-1
Show all juju.worker.uniter logging module messages that are also unit wordpress/0 messages, and then show any new log messages which match the filter:
 juju debug-log --replay
      --include-module juju.worker.uniter \
      --include unit-wordpress-0
Show all messages from the juju.worker.uniter module, except those sent from machine-3 or machine-4, and then stop:
   juju debug-log --replay --no-tail
        --exclude machine-3 \
        --exclude machine-4
To see all WARNING and ERROR messages and then continue showing any new WARNING and ERROR messages as they are logged:
juju debug-log --replay --level WARNING
See also:
status, ssh
