Usage
juju debug-code [options] <unit name> [hook or action names]
Launch a tmux session to debug hooks and/or actions.
Description
Interactively debug hooks and actions on a unit.
Similar to ‘juju debug-hooks’ but rather than dropping you into a shell prompt,
it runs the hooks and sets the JUJU_DEBUG_AT
environment variable. Charms that implement support for this should use it to set breakpoints based on the environment variable.
See the “juju help ssh” for information about SSH related options
accepted by the debug-hooks command.
Options
Global Options
--debug (= false)
equivalent to --show-log --logging-config=<root>=DEBUG
-h, --help (= false)
--logging-config (= "")
specify log levels for modules
--quiet (= false)
show no informational output
--show-log (= false)
if set, write the log file to stderr
--verbose (= false)
show more verbose output
Command Options:
--at (= "all")
interpreted by the charm for where you want to stop, defaults to 'all'
-m, --model (= "")
Model to operate in. Accepts [<controller name>:]<model name>|<model UUID>
--no-host-key-checks (= false)
Skip host key checking (INSECURE)
--proxy (= false)
Proxy through the API server
--pty (= <auto>)
Enable pseudo-tty allocation
