The information in this doc is based on Juju version 3.5.3, and may not accurately reflect other versions of Juju.
See also: deploy, status, model-config, controller-config
Gets, sets, or resets configuration for a deployed application.
Usage
juju config [options] <application name> [--branch <branch-name>] [--reset <key[,key]>] [<attribute-key>][=<value>] ...]
Options
Flag | Default | Usage |
-B , --no-browser-login |
--color |
false | Use ANSI color codes in output |
--file |
path to yaml-formatted configuration file | |
--format |
yaml | Specify output format (json|yaml) |
-m , --model |
--no-color |
false | Disable ANSI color codes in tabular output |
-o , --output |
Specify an output file | |
--reset |
Reset the provided comma delimited keys |
Examples
To view all configuration values for an application, run
juju config mysql --format json
To set a configuration value for an application, run
juju config mysql foo=bar
To set some keys and reset others:
juju config mysql key1=val1 key2=val2 --reset key3,key4
To set a configuration value for an application from a file:
juju config mysql --file=path/to/cfg.yaml
Details
To view all configuration values for an application:
juju config <app>
By default, the config will be printed in yaml format. You can instead print it in json format using the --format flag:
juju config <app> --format json
To view the value of a single config key, run
juju config <app> key
To set config values, run
juju config <app> key1=val1 key2=val2 ...
This sets “key1” to “val1”, etc. Using the @ directive, you can set a config key’s value to the contents of a file:
juju config <app> key=@/tmp/configvalue
You can also reset config keys to their default values:
juju config <app> --reset key1
juju config <app> --reset key1,key2,key3
You may simultaneously set some keys and reset others:
juju config <app> key1=val1 key2=val2 --reset key3,key4
Config values can be imported from a yaml file using the --file flag:
juju config <app> --file=path/to/cfg.yaml
The yaml file should be in the following format:
apache2: # application name
servername: "example.com" # key1: val1
lb_balancer_timeout: 60 # key2: val2
This allows you to e.g. save an app’s config to a file:
juju config app1 > cfg.yaml
and then import the config later. You can also read from stdin using “-”, which allows you to pipe config values from one app to another:
juju config app1 | juju config app2 --file -
You can simultaneously read config from a yaml file and set/reset config keys as above. The command-line args will override any values specified in the file.
By default, any configuration changes will be applied to the currently active branch. A specific branch can be targeted using the --branch option. Changes can be immediately be applied to the model by specifying --branch=master. For example:
juju config apache2 --branch=master servername=example.com
juju config apache2 --branch test-branch servername=staging.example.com
Rather than specifying each setting name/value inline, the --file flag option may be used to provide a list of settings to be updated as a yaml file. The yaml file contents must include a single top-level key with the application’s name followed by a dictionary of key/value pairs that correspond to the names and values of the settings to be set. For instance, to configure apache2, the following yaml file can be used:
apache2:
If the above yaml document is stored in a file called config.yaml, the following command can be used to apply the config changes:
juju config apache2 --file config.yaml
Finally, the --reset flag can be used to revert one or more configuration settings back to their default value as defined in the charm metadata:
juju config apache2 --reset servername
juju config apache2 --reset servername,lb_balancer_timeout
