Usage: juju agreements [options]
Summary:
List user’s agreements.
Options:
-c, --controller (= "")
Controller to operate in
--format (= tabular)
Specify output format (json|tabular|yaml
-o, --output (= "")
Specify an output file
Details:
Charms may require a user to accept its terms in order for it to be deployed. In other words, some applications may only be installed if a user agrees to accept some terms defined by the charm. This command lists the terms that the user has agreed to.
See also:
Aliases:
list-agreements
