Charmed Spark Documentation - Tutorial Introduction
Charmed Spark Solution Tutorial
The Charmed Spark solution delivers Spark utility client applications, that allow for simple and seamless usage of Apache Spark on Kubernetes.
This tutorial takes you through the journey of setting up necessary environment to run Charmed Spark and teaches you how to run Spark jobs using both interactive shell and batch jobs. You’ll also learn how to use Charmed Spark with streaming workloads and how to enable monitoring of the Spark cluster.
This tutorial can be divided into the following sections:
While this tutorial intends to guide and teach you along the way, it will be most beneficial if you already have a familiarity with:
  • Basic terminal commands.
  • General familiarity with Kubernetes commands and concepts (e.g. kubectl general usage)
Let’s proceed to set up the environment needed for this tutorial in the next section.
