Manage units
In this section, you will learn to scale your Charmed PostgreSQL by adding or removing units (replicas).
This is part of the Charmed PostgreSQL VM Tutorial.
Please refer to the Overview for more information.
Add and remove units
The Charmed PostgreSQL VM operator uses a PostgreSQL Patroni-based cluster for scaling. It provides features such as automatic membership management, fault tolerance, and automatic failover. The charm uses Postgres’s Synchronous replication with Patroni.
Disclaimer: This tutorial hosts all replicas on the same machine. This should not be done in a production environment.
To enable high availability in a production environment, replicas should be hosted on different servers to maintain isolation.
Add cluster members (replicas)
To add two replicas to your deployed PostgreSQL application, run
juju add-unit postgresql -n 2
You can now watch the scaling process in live using: juju status --watch 1s
. It usually takes several minutes for new cluster members to be added.
You’ll know that all three nodes are in sync when juju status
reports Workload=active
and Agent=idle
tutorial overlord localhost/localhost 3.1.7 unsupported 10:16:44+01:00
postgresql active 3 postgresql 14/stable 281 no
postgresql/0* active idle 0 10.89.49.129 Primary
postgresql/1 active idle 1 10.89.49.197
postgresql/2 active idle 2 10.89.49.175
0 started 10.89.49.129 juju-a8a31d-0 jammy Running
1 started 10.89.49.197 juju-a8a31d-1 jammy Running
2 started 10.89.49.175 juju-a8a31d-2 jammy Running
Remove cluster members (replicas)
Removing a unit from the application, scales down the replicas.
Before we scale them down, list all the units with juju status
. You will see three units: postgresql/0
, postgresql/1
, and postgresql/2
. Each of these units hosts a PostgreSQL replica.
To remove the replica hosted on the unit postgresql/2
enter:
juju remove-unit postgresql/2
You’ll know that the replica was successfully removed when juju status --watch 1s
reports:
tutorial overlord localhost/localhost 3.1.7 unsupported 10:17:14+01:00
postgresql active 2 postgresql 14/stable 281 no
