Charmed PostgreSQL VM Tutorial > 6. Enable security
Enable security with TLS
Transport Layer Security (TLS) is a protocol used to encrypt data exchanged between two applications. Essentially, it secures data transmitted over a network.
Typically, enabling TLS internally within a highly available database or between a highly available database and client/server applications requires a high level of expertise. This has all been encoded into Charmed PostgreSQL so that configuring TLS requires minimal effort on your end.
TLS is enabled by integrating Charmed PostgreSQL with the Self Signed Certificates Charm. This charm centralises TLS certificate management consistently and handles operations like providing, requesting, and renewing TLS certificates.
In this section, you will learn how to enable security in your PostgreSQL deployment using TLS encryption.
Self-signed certificates are not recommended for a production environment.
Check this guide for an overview of the TLS certificates charms available.
Configure TLS
Before enabling TLS on Charmed PostgreSQL VM, we must deploy the self-signed-certificates
charm:
juju deploy self-signed-certificates --config ca-common-name="Tutorial CA"
Wait until the self-signed-certificates
is up and active, use juju status --watch 1s
to monitor the progress:
tutorial overlord localhost/localhost 3.1.7 unsupported 10:31:40+01:00
postgresql active 2 postgresql 14/stable 281 no
self-signed-certificates active 1 self-signed-certificates stable 72 no
postgresql/0* active idle 0 10.89.49.129 Primary
postgresql/1 active idle 1 10.89.49.197
self-signed-certificates/0* active idle 3 10.89.49.185
0 started 10.89.49.129 juju-a8a31d-0 jammy Running
1 started 10.89.49.197 juju-a8a31d-1 jammy Running
4 started 10.89.49.185 juju-a8a31d-3 jammy Running
Add external TLS certificate
To enable TLS on Charmed PostgreSQL VM, integrate the two applications:
juju integrate postgresql self-signed-certificates
Check the TLS certificate in use:
Use openssl
to connect to the PostgreSQL and check the TLS certificate in use. Note that your leader unit’s IP address will likely be different to the one shown below:
> openssl s_client -starttls postgres -connect 10.89.49.129:5432 | grep Issuer
depth=1 C = US, CN = Tutorial CA
verify error:num=19:self-signed certificate in certificate chain
Congratulations! PostgreSQL is now using TLS certificate generated by the external application self-signed-certificates
Remove external TLS certificate
To remove the external TLS, remove the integration:
juju remove-relation postgresql self-signed-certificates
no peer certificate available
No client certificate CA names sent
The Charmed PostgreSQL VM application is not using TLS anymore.
