Charmed PostgreSQL K8s Tutorial > 1. Set up the environment
In this page, we will set up a development environment with the required components for deploying Charmed PostgreSQL K8s.
Minimum requirements
Before we start, make sure your machine meets the following requirements:
- Ubuntu 20.04 (Focal) or later.
- 8GB of RAM.
- 2 CPU threads.
- Access to the internet for downloading the required OCI/ROCKs and charms.
Multipass environment
Multipass is a quick and easy way to launch virtual machines running Ubuntu. It uses the cloud-init standard to install and configure all the necessary parts automatically.
Install Multipass from Snap:
sudo snap install multipass
Launch a new VM using the charm-dev cloud-init config:
multipass launch --cpus 4 --memory 8G --disk 30G --name my-vm charm-dev
Note: All ‘multipass launch’ parameters are described here.
The Multipass list of commands is short and self-explanatory. For example, to show all running VMs, just run the command multipass list
As soon as a new VM has started, access it using
multipass shell my-vm
Note: If at any point you’d like to leave a Multipass VM, enter Ctrl+D
or type exit
All necessary components have been pre-installed inside the VM already, like MicroK8s and Juju. The files /var/log/cloud-init.log
and /var/log/cloud-init-output.log
contain all low-level installation details.
A controller can work with different models. Set up a specific model for Charmed PostgreSQL K8s named ‘tutorial’:
juju add-model tutorial
You can now view the model you created above by running the command juju status
. You should see something similar to the following example output:
tutorial charm-dev microk8s/localhost 2.9.42 unsupported 11:56:38+01:00
Model "admin/tutorial" is empty.
