Manage Passwords
This is part of the Charmed PostgreSQL Tutorial. Please refer to this page for more information and the overview of the content.
Passwords
When we accessed PostgreSQL earlier in this tutorial, we needed to use a password manually. Passwords help to secure our database and are essential for security. Over time it is a good practice to change the password frequently. Here we will go through setting and changing the password for the admin user.
Retrieve the password
As previously mentioned, the operator’s password can be retrieved by running the get-password
action on the Charmed PostgreSQL K8s application:
juju run-action postgresql-k8s/leader get-password --wait
unit-postgresql-k8s-0:
UnitId: postgresql-k8s/0
results:
password: SYhCduijXTAfg9mU
status: completed
timing:
completed: 2023-03-20 11:10:33 +0000 UTC
enqueued: 2023-03-20 11:10:32 +0000 UTC
started: 2023-03-20 11:10:33 +0000 UTC
Rotate the password
You can change the operator’s password to a new random password by entering:
juju run-action postgresql-k8s/leader set-password --wait
results:
password: 7CYrRiBrC4du3ToX
status: completed
timing:
completed: 2023-03-20 11:10:47 +0000 UTC
enqueued: 2023-03-20 11:10:46 +0000 UTC
started: 2023-03-20 11:10:47 +0000 UTC
Please notice the status: completed
above which means the password has been successfully updated. The password should be different from the previous password.
Set the new password
You can change the password to a specific password by entering:
juju run-action postgresql-k8s/leader set-password password=my-password --wait
results:
password: my-password
status: completed
timing:
completed: 2023-03-20 11:11:06 +0000 UTC
enqueued: 2023-03-20 11:11:02 +0000 UTC
started: 2023-03-20 11:11:05 +0000 UTC
The password should match whatever you passed in when you entered the command.
Set the new password for the specific user
You can change the password for a specific user by entering:
juju run-action postgresql-k8s/leader set-password username=my-user password=my-password --wait
Read more about internal operator users here.
