Charmed PostgreSQL K8s How To - Restore a local backup
How to restore a local backup
This is a guide on how to restore a locally made backup.
To restore a backup that was made from a different cluster, (i.e. cluster migration via restore), see How to migrate cluster using backups.
  • juju run replaces juju run-action --wait in juju v.2.9
  • juju integrate replaces juju relate and juju add-relation in juju v.2.9
List backups
To view the available backups to restore, use the command list-backups:
juju run postgresql-k8s/leader list-backups
This should show your available backups like in the sample output below:
    backups: |-
      backup-id             | backup-type  | backup-status
      YYYY-MM-DDTHH:MM:SSZ  | physical     | finished
Restore backup
To restore a backup from that list, run the restore command and pass the corresponding backup-id:
juju run postgresql-k8s/leader restore backup-id=YYYY-MM-DDTHH:MM:SSZ
Your restore will then be in progress.
