How to manage integrated applications
juju run
injuju v.2.9
juju integrate
replacesjuju relate
andjuju add-relation
injuju v.2.9
Create an integration
New postgresql_client
interface
Integrations (or “relations” in juju v.2.9
) with new applications are supported via the postgresql_client interface.
To create an integration, run
juju integrate postgresql-k8s application
To remove an integration:
juju remove-relation postgresql-k8s application
Legacy pgsql
interface
We have also added support for the database legacy relation from the original version of the charm via the pgsql
interface. Note that this interface is deprecated.
juju integrate postgresql-k8s:db mattermost-k8s:db
Extended permissions can be requested using the db-admin
endpoint:
juju integrate postgresql-k8s:db-admin mattermost-k8s:db
Rotate application passwords
To rotate the passwords of users created for integrated applications, the integration should be removed and integrated again. This process will generate a new user and password for the application.
juju remove-relation application postgresql-k8s
juju add-relation application postgresql-k8s
Internal operator user
The operator
user is used internally by the Charmed PostgreSQL K8s Operator. The set-password
action can be used to rotate its password.
To set a specific password for the operator
user, run
juju run postgresql-k8s/leader set-password password=<password>
To randomly generate a password for the operator
user, run
