Charmed PostgreSQL How-to - Restore BackupTODO
This is a How-To for performing a basic restore (restoring a locally made backup). To restore a backup that was made from the a different cluster, (i.e. cluster migration via restore), please reference the Cluster Migration via Restore How-To:
Restoring from a backup requires that you:
To view the available backups to restore you can enter the command list-backups:
juju run-action postgresql/leader list-backups --wait
This should show your available backups
    backups: |-
      backup-id             | backup-type  | backup-status
      YYYY-MM-DDTHH:MM:SSZ  | physical     | finished
To restore a backup from that list, run the restore command and pass the backup-id to restore:
juju run-action postgresql/leader restore backup-id=YYYY-MM-DDTHH:MM:SSZ --wait
Your restore will then be in progress.
