Enable Security in your MySQL deployment
Hint: Use Juju 3. Otherwise replace
juju integrate ...
withjuju relate ...
for Juju 2.9.
This is part of the Charmed MySQL Tutorial. Please refer to this page for more information and the overview of the content.
Transport Layer Security (TLS)
TLS is used to encrypt data exchanged between two applications; it secures data transmitted over the network. Typically, enabling TLS within a highly available database, and between a highly available database and client/server applications, requires domain-specific knowledge and a high level of expertise. Fortunately, the domain-specific knowledge has been encoded into Charmed MySQL. This means (re-)configuring TLS on Charmed MySQL is readily available and requires minimal effort on your end.
The production ready TLS Certificates Charm is available on CharmHub. It centralizes TLS certificate management in a consistent manner and handles providing, requesting, and renewing TLS certificates. As for the tutorial purpose, we will choose simplified analogue Self Signed Certificates. Again, relations come in handy here as TLS is enabled via relations; i.e. by relating Charmed MySQL to the “Self Signed Certificates” charm.
Configure TLS
Before enabling TLS on Charmed MySQL we must first deploy the self-signed-certificates
charm:
juju deploy self-signed-certificates --channel edge
Wait until the self-signed-certificates
is up and active, use juju status --watch 1s
to monitor the progress:
tutorial overlord localhost/localhost 2.9.42 unsupported 00:40:42+01:00
mysql 8.0.32-0ubun... active 2 mysql 8.0/stable 147 no
self-signed-certificates active 1 self-signed-certificates edge 27 no
mysql/0* active idle 0 10.234.188.135 Primary
mysql/1 active idle 1 10.234.188.214
self-signed-certificates/1* active idle 6 10.234.188.19
0 started 10.234.188.135 juju-ff9064-0 jammy Running
1 started 10.234.188.214 juju-ff9064-1 jammy Running
6 started 10.234.188.19 juju-ff9064-6 focal Running
Note: this tutorial uses self-signed certificates; self-signed certificates should not be used in a production cluster.
Add external TLS certificate
To enable TLS on Charmed MySQL, integrate the two applications:
juju integrate mysql self-signed-certificates
Check the TLS certificate in use:
Use openssl
to connect to the MySQL and check the TLS certificate in use:
> openssl s_client -starttls mysql -connect 10.234.188.135:3306 | grep Issuer
depth=1 C = US, CN = self-signed-certificates-operator
Congratulations! MySQL is now using TLS certificate generated by the external application self-signed-certificates
Remove external TLS certificate
To remove the external TLS and return to the locally generate one, unrelate applications:
juju remove-relation mysql self-signed-certificates
The output should be similar to:
depth=1 CN = MySQL_Server_8.0.32_Auto_Generated_CA_Certificate
The Charmed MySQL application reverted to the placeholder certificate that was created locally during the MySQL server installation.
