Get a Charmed MySQL up and running
This is part of the Charmed MySQL Tutorial. Please refer to this page for more information and the overview of the content.
Deploy Charmed MySQL
To deploy Charmed MySQL, all you need to do is run the following command, which will fetch the charm from Charmhub and deploy it to your model:
juju deploy mysql --channel edge
Juju will now fetch Charmed MySQL and begin deploying it to the LXD cloud. This process can take several minutes depending on how provisioned (RAM, CPU, etc) your machine is. You can track the progress by running:
juju status --watch 1s
This command is useful for checking the status of Charmed MySQL and gathering information about the machines hosting Charmed MySQL. Some of the helpful information it displays include IP addresses, ports, state, etc. The command updates the status of Charmed MySQL every second and as the application starts you can watch the status and messages of Charmed MySQL change. Wait until the application is ready - when it is ready, juju status
will show:
tutorial overlord localhost/localhost 2.9.38 unsupported 22:52:47+01:00
mysql 8.0.32-0ubun... active 1 mysql edge 95 no Unit is ready: Mode: RW
mysql/0* active idle 0 10.234.188.135 Unit is ready: Mode: RW
0 started 10.234.188.135 juju-ff9064-0 jammy Running
To exit the screen with juju status --watch 1s
, enter Ctrl+c
If you want to further inspect juju logs, can watch for logs with juju debug-log
More info on logging at juju logs.
Access MySQL
! Disclaimer: this part of the tutorial accesses MySQL via the
root
user. Do not directly interface with the root user in a production environment. In a production environment always create a separate user using Data Integrator and connect to MySQL with that user instead. Later in the section covering Relations we will cover how to access MySQL without the root user.
The first action most users take after installing MySQL is accessing MySQL. The easiest way to do this is via the MySQL Command-Line Client mysql
. Connecting to the database requires that you know the values for host
, username
and password
. To retrieve the necessary fields please run Charmed MySQL action get-password
juju run-action mysql/leader get-password --wait
unit-mysql-0:
UnitId: mysql/0
results:
password: <password>
username: root
status: completed
timing:
completed: 2023-01-29 21:58:53 +0000 UTC
enqueued: 2023-01-29 21:58:52 +0000 UTC
started: 2023-01-29 21:58:53 +0000 UTC
Note: to request a password for a different user, use an option username
juju run-action mysql/leader get-password username=myuser --wait
The host’s IP address can be found with juju status
(the unit hosting the MySQL application):
To access the units hosting Charmed MySQL use:
mysql -h 10.234.188.135 -uroot -p<password>
Note: if at any point you’d like to leave the unit hosting Charmed MySQL, enter Ctrl+d
or type exit
The another way to access MySQL server is to ssh into Juju machine:
juju ssh mysql/leader
Inside the Juju virtual machine the root
user can access MySQL DB simply calling mysql
Welcome to Ubuntu 22.04.1 LTS (GNU/Linux 5.19.0-29-generic x86_64)
ubuntu@juju-ff9064-0:~$ sudo mysql -e "show databases"
| Database |
| information_schema |
| mysql |
| mysql_innodb_cluster_metadata |
| performance_schema |
| sys |
Welcome to the MySQL monitor. Commands end with ; or \g.
Your MySQL connection id is 56
Server version: 8.0.32-0ubuntu0.22.04.2 (Ubuntu)
Copyright (c) 2000, 2023, Oracle and/or its affiliates.
Oracle is a registered trademark of Oracle Corporation and/or its
affiliates. Other names may be trademarks of their respective
owners.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
mysql>
Note: if at any point you’d like to leave the mysql client, enter Ctrl+d
or type exit
You can now interact with MySQL directly using any MySQL Queries. For example entering SELECT VERSION(), CURRENT_DATE;
should output something like:
mysql> SELECT VERSION(), CURRENT_DATE;
| VERSION() | CURRENT_DATE |
| 8.0.32-0ubuntu0.22.04.2 | 2023-01-29 |
1 row in set (0.00 sec)
Feel free to test out any other MySQL queries. When you’re ready to leave the mysql shell you can just type exit
. Once you’ve typed exit
you will be back in the host of Charmed MySQL (mysql/0
). Exit this host by once again typing exit
. Now you will be in your original shell where you first started the tutorial; here you can interact with Juju and LXD.## Deploy Charmed MySQL
will show:
, enter Ctrl+c
Access MySQL
root
, username
and password
unit-mysql-0:
UnitId: mysql/0
results:
username: root
status: completed
timing:
or type exit
| Database |
| mysql |
| sys |
owners.
mysql>
or type exit
