Charmed MySQL revision 203 Archived. See revision 232.
The revision is currently available in
8.0/candidate
only (WIP).
Dear community, this is to inform you that new Canonical Charmed MySQL is published in 8.0/stable
charmhub channel for IAAS/VM.
The features you can start using today:
- Add profile-limit-memory option [PR#331][DPE-2654]
- Add logrotation for general/error/slowquery text logs [PR#329][DPE-1796]
- Use labels for internal Juju secrets in [PR#348][DPE-2886]
- Updated data-platform-libs for external secrets [PR#333]
- All the functionality from the previous revisions
Bugfixes included:
Highlights for the current revision:
- Fixed single unit upgrade [PR#340][DPE-2662]
- Fixed dateformat in logrotate config to avoid causing filename conflicts after 24hrs of uptime [PR#363][DPE-3063]
- Stops logging FLUSH LOG statements to the MySQL binlog which is causing GTID conflicts and prevents the member from self-healing [PR#336]
What is inside the charms:
- Charmed MySQL ships the latest MySQL “8.0.34-0ubuntu0.22.04.1”
- CLI mysql-shell updated to “8.0.34-0ubuntu0.22.04.1~ppa1”
- Backup tools xtrabackup/xbcloud updated to “8.0.34-29”
- The Prometheus mysqld-exporter is “0.14.0-0ubuntu0.22.04.1~ppa1”
- VM charms based on Charmed MySQL SNAP (Ubuntu LTS “22.04” - ubuntu:22.04-based) revision 69
- Principal charms supports the latest LTS series “22.04” only
- Subordinate charms support LTS “22.04” and “20.04” only
Technical notes:
- Upgrade (
juju refresh
) is possible from this revision 196+ - Use this operator together with a modern operator “MySQL Router”
- Please check additionally the previously posted restrictions
How to reach us:
Contribute to the project!
Hints:
Please check all the previous release notes if you are jumping over the several stable revisions!
