Charmed MongoDB Tutorial | Clean up the environment
This page is from the Charmed MongoDB Tutorials
In this tutorial, we’ve successfully:
  • Deployed MongoDB on LXD
  • Scaled our deployment
  • Added and removed database users
  • Enabled and disabled TLS
You may now keep your MongoDB deployment running to continue experimenting, or remove it entirely to free up resources on your machine.
Remove Charmed MongoDB
Warning: If you remove Charmed MongoDB as shown below, you will lose all data stored in MongoDB.
To remove Charmed MongoDB, delete the juju model it is hosted on:
juju destroy-model tutorial --destroy-storage --force
Then, remove the overlord Juju controller:
juju destroy-controller overlord
Remove Juju
Warning: If you remove Juju as shown below, you will lose access to any other applications you have hosted on Juju.
To remove Juju altogether, enter:
sudo snap remove juju --purge
You’ve successfully completed our Charmed MongoDB tutorial :tada:
What next?
Contact us!
