Charmed MongoDB Tutorials > Deploy a replica set > 7. Enable security
Enable security in your MongoDB deployment
Transport Layer Security (TLS) is used to encrypt data exchanged between two applications; it secures data transmitted over the network. Typically, enabling TLS within a highly available database, and between a highly available database and client/server applications, requires domain-specific knowledge and a high level of expertise. Fortunately, the domain-specific knowledge has been encoded into Charmed MongoDB K8S. This means enabling TLS on Charmed MongoDB K8S is readily available and requires minimal effort on your end.
Again, relations come in handy here as TLS is enabled via relations; i.e. by relating Charmed MongoDB K8s to the Self Signed Certificates Charm. This charm centralises self-signed certificate management and handles providing, requesting, and renewing self-signed TLS certificates.
Disclaimer: In this tutorial we use self-signed certificates provided by the self-signed-certificates-operator
This is not recommended for a production environment.
For production environments, check the collection of Charmhub operators that implement the tls-certificate
interface, and choose the most suitable for your use-case.
Configure TLS
Before enabling TLS on Charmed MongoDB we must first deploy theself-signed-certificates
charm:
Wait until the self-signed-certificates
app is active
with juju status --watch 1s
, like in the output below.
tutorial overlord localhost/localhost 3.4.0 unsupported 09:35:14+01:00
mongodb active 1 mongodb 6/beta 149 no Primary
self-signed-certificates active 1 self-signed-certificates stable 72 no
mongodb/0* active idle 0 10.67.56.90 27017/tcp Primary
self-signed-certificates/1* active idle 2 10.67.56.137
0 started 10.67.56.90 juju-fab81d-0 ubuntu@22.04 Running
2 started 10.67.56.137 juju-fab81d-2 ubuntu@22.04 Running
Now that self-signed-certificates
has finished deploying, we can configure it with:
juju config self-signed-certificates ca-common-name="Tutorial CA"
Enable TLS
To enable TLS on Charmed MongoDB, integrate the two applications:juju integrate self-signed-certificates mongodb
Connect to MongoDB with TLS
Like before, generate and save the URI that is used to connect to MongoDB:export URI=mongodb://$DB_USERNAME:$DB_PASSWORD@$HOST_IP/$DB_NAME?replicaSet=$REPL_SET_NAME
echo $URI
Now ssh into mongodb/0
juju ssh mongodb/0
We are now in the unit that is hosting Charmed MongoDB.
Once TLS has been enabled, we will need to change how we connect to MongoDB. We will need to specify the TLS CA file along with the TLS Certificate file that were automatically created when we integrated the two charms.
You will find these files on the units hosting the Charmed MongoDB application in the folder /var/snap/charmed-mongodb/common/etc/mongod
If you enter:
ls /var/snap/charmed-mongodb/current/etc/mongod/external*
you should see the following external certificate file and external CA files:
/var/snap/charmed-mongodb/current/etc/mongod/external-ca.crt
/var/snap/charmed-mongodb/current/etc/mongod/external-cert.pem
As before, we will connect to MongoDB via the saved MongoDB URI. Connect using the saved URI and the following TLS options:
sudo charmed-mongodb.mongosh mongodb://$DB_USERNAME:$DB_PASSWORD@$HOST_IP/$DB_NAME?replicaSet=$REPL_SET_NAME --tls --tlsCAFile /var/snap/charmed-mongodb/current/etc/mongod/external-ca.crt --tlsCertificateKeyFile /var/snap/charmed-mongodb/current/etc/mongod/external-cert.pem
You have successfully connected to MongoDB with TLS!
When you are ready, leave the MongoDB shell by typing exit
. You will be back in the host of Charmed MongoDB (mongodb/0
). Exit this host by typing exit
again.
You should now be at the original shell where you can interact with Juju and LXD.
Disable TLS
To disable TLS, simply remove the integration between the two applications:juju remove-relation mongodb self-signed-certificates
Next step: 8. Clean up the environment
