Charmed Apache Kafka Documentation - Tutorial Deploy Apache Kafka
This is part of the Charmed Apache Kafka Tutorial. Please refer to this page for more information and an overview of the content.
Deploy Charmed Apache Kafka (and Charmed ZooKeeper)
To deploy Charmed Apache Kafka, all you need to do is run the following commands, which will automatically fetch Apache Kafka and Apache ZooKeeper charms from Charmhub and deploy them to your model. For example, to deploy a cluster of five Apache ZooKeeper units and three Apache Kafka units, you can simply run:
$ juju deploy zookeeper -n 5
$ juju deploy kafka -n 3 --trust
After this, it is necessary to connect them:
$ juju relate kafka zookeeper
Juju will now fetch Charmed Apache Kafka and Charmed Apache Zookeeper and begin deploying them to the LXD cloud. This process can take several minutes depending on how provisioned (RAM, CPU, etc) your machine is. You can track the progress by running:
juju status --watch 1s
This command is useful for checking the status of Charmed Apache ZooKeeper and Charmed Apache Kafka and gathering information about the machines hosting the two applications. Some of the helpful information it displays includes IP addresses, ports, state, etc. The command updates the status of the cluster every second and as the application starts you can watch the status and messages of Charmed Apache Kafka and Charmed Apache ZooKeeper change.
Wait until the application is ready - when it is ready, juju status --watch 1s will show:
Model     Controller  Cloud/Region         Version  SLA          Timestamp
tutorial  overlord    localhost/localhost  3.1.6    unsupported  08:20:12Z
App        Version  Status  Scale  Charm      Channel      Rev  Exposed  Message
kafka               active      3  kafka      3/stable     147  no
zookeeper           active      5  zookeeper  3/stable     114  no
Unit          Workload  Agent  Machine  Public address  Ports  Message
kafka/0       active    idle   5        10.244.26.43           machine system settings are not optimal - see logs for info
kafka/1*      active    idle   6        10.244.26.6            machine system settings are not optimal - see logs for info
kafka/2       active    idle   7        10.244.26.19           machine system settings are not optimal - see logs for info
zookeeper/0   active    idle   0        10.244.26.251
zookeeper/1   active    idle   1        10.244.26.129
zookeeper/2   active    idle   2        10.244.26.121
zookeeper/3*  active    idle   3        10.244.26.28
zookeeper/4   active    idle   4        10.244.26.174
Machine  State    Address        Inst id        Series  AZ  Message
0        started  10.244.26.251  juju-f1a2cd-0  jammy       Running
1        started  10.244.26.129  juju-f1a2cd-1  jammy       Running
2        started  10.244.26.121  juju-f1a2cd-2  jammy       Running
3        started  10.244.26.28   juju-f1a2cd-3  jammy       Running
4        started  10.244.26.174  juju-f1a2cd-4  jammy       Running
5        started  10.244.26.43   juju-f1a2cd-5  jammy       Running
6        started  10.244.26.6    juju-f1a2cd-6  jammy       Running
7        started  10.244.26.19   juju-f1a2cd-7  jammy       Running
To exit the screen with juju status --watch 1s, enter Ctrl+c.
Access Apache Kafka cluster
To watch the process, juju status can be used. Once all the units show as active|idle the credentials to access a broker can be queried with:
juju run kafka/leader get-admin-credentials
The output of the previous command is something like this:
client-properties: |-
  sasl.jaas.config=org.apache.kafka.common.security.scram.ScramLoginModule required username="admin" password="e2sMfYLQg7sbbBMFTx1qlaZQKTUxr09x";
  bootstrap.servers=10.244.26.19:9092,10.244.26.6:9092,10.244.26.43:9092
  security.protocol=SASL_PLAINTEXT
  sasl.mechanism=SCRAM-SHA-512
password: e2sMfYLQg7sbbBMFTx1qlaZQKTUxr09x
username: admin
Providing you the username and password of the Apache Kafka cluster admin user.
When no other application is related to Apache Kafka, the cluster is secured-by-default and external listeners (bound to port 9092) are disabled, thus preventing any external incoming connection.
Nevertheless, it is still possible to run a command from within the Apache Kafka cluster using the internal listeners in place of the external ones. The internal endpoints can be constructed by replacing the 19092 port in the bootstrap.servers returned in the output above, for example:
INTERNAL_LISTENERS=$(juju run kafka/leader get-admin-credentials | grep "bootstrap.servers" | cut -d "=" -f2 | sed -s "s/\:9092/:19092/g")
Once you have fetched the INTERNAL_LISTENERS, log in to one of the Kafka containers in one of the units:
juju ssh kafka/leader sudo -i
When the unit is started, the Charmed Apache Kafka Operator installs the charmed-kafka Snap in the unit that provides a number of entrypoints (that corresponds to the bin commands in the Apache Kafka distribution) for performing various administrative tasks, e.g charmed-kafka.config to update cluster configuration, charmed-kafka.topics for topic management, and many more! Within the machine, the Charmed Apache Kafka Operator also creates a client.properties file that already provides the relevant settings to connect to the cluster using the CLI
CLIENT_PROPERTIES=/var/snap/charmed-kafka/current/etc/kafka/client.properties
For example, in order to create a topic, you can run:
charmed-kafka.topics \
    --create --topic test_topic \
    --bootstrap-server $INTERNAL_LISTENERS \
    --command-config $CLIENT_PROPERTIES
You can similarly then list the topic, using:
    --list \
making sure the topic was successfully created.
You can finally delete the topic, using:
    --delete --topic test_topic \
Other available Apache Kafka bin commands can also be found with:
snap info charmed-kafka
What’s next?
However, although the commands above can run within the cluster, it is generally recommended during operations to enable external listeners and use these for running the admin commands from outside the cluster. To do so, as we will see in the next section, we will deploy a data-integrator charm and relate it to Charmed Apache Kafka.
Hello!
Very nice tutorial!
I have some small suggestions to make.
Under the section “Deploy”, where the following is mentioned:
To deploy Charmed Kafka, all you need to do is run the following command
I think it should be commands instead of command.
I believe it would be nice to mention that the commands will create a 5 instance Zookeeper and a 3 instance Kafka cluster. So together with the previous suggestion, I propose that it could be written as:
To deploy Charmed Kafka, all you need to do is run the juju deploy commands which will automatically fetch Kafka and Zookeeper charms from Charmhub and deploy them to your model. For example, to deploy a 5 instance Zookeeper and a 3 instance Kafka cluster, you can simply run the following commands:
Also, close to the end of the tutorial, where it says:
However, even for running the commands above, listeners must be enable.
I believe it should be enabled instead of enable.
Thank you!
